Time Before: 0.01203 seconds
Time After: 0.01535 seconds
Time Taken: 0.00332 seconds
Time Before: 0.01545 seconds
Time After: 0.01599 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01625 seconds
Time After: 0.01638 seconds
Time Before: 0.01723 seconds
Time After: 0.02022 seconds
Time Taken: 0.00299 seconds
Time Before: 0.01643 seconds
Time After: 0.02402 seconds
Time Taken: 0.00759 seconds
Time Before: 0.03009 seconds
Time After: 0.03053 seconds
Time Before: 0.03420 seconds
Time After: 0.03539 seconds
Time Before: 0.02925 seconds
Time After: 0.03559 seconds
Time Taken: 0.00634 seconds
Time Before: 0.06336 seconds
Time After: 0.06349 seconds
Time Before: 0.07325 seconds
Time After: 0.07454 seconds
Time Before: 0.08128 seconds
Time After: 0.08146 seconds
Time Before: 0.08445 seconds
Time After: 0.08668 seconds
Time Taken: 0.00222 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=26309', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.10405 seconds
Time After: 0.10433 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
