Time Before: 0.01021 seconds
Time After: 0.01233 seconds
Time Taken: 0.00212 seconds
Time Before: 0.01240 seconds
Time After: 0.01280 seconds
Time Before: 0.01301 seconds
Time After: 0.01316 seconds
Time Before: 0.01391 seconds
Time After: 0.01614 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01321 seconds
Time After: 0.02068 seconds
Time Taken: 0.00748 seconds
Time Before: 0.02495 seconds
Time After: 0.02530 seconds
Time Before: 0.02770 seconds
Time After: 0.02891 seconds
Time Before: 0.02416 seconds
Time After: 0.02911 seconds
Time Taken: 0.00495 seconds
Time Before: 0.05029 seconds
Time After: 0.05044 seconds
Time Before: 0.05863 seconds
Time After: 0.05987 seconds
End call of global.php: 0.061950922012329
Time Before: 0.06527 seconds
Time After: 0.06546 seconds
Time Before: 0.06771 seconds
Time After: 0.06919 seconds
SET lastactivity = 1780662754, location = '/forums/private.php?do=newpm&explain=1&u=26466', badlocation = 1
Time Before: 0.08633 seconds
Time After: 0.08664 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.085253953933716 seconds with 9 queries, spending 0.0076971054077148 doing MySQL queries and 0.077556848526001 doing PHP things.
