Time Before: 0.00236 seconds
Time After: 0.00336 seconds
Time Taken: 0.00100 seconds
Time Before: 0.00344 seconds
Time After: 0.00379 seconds
Time Before: 0.00404 seconds
Time After: 0.00418 seconds
Time Before: 0.00491 seconds
Time After: 0.00856 seconds
Time Taken: 0.00366 seconds
Time Before: 0.00423 seconds
Time After: 0.01200 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01412 seconds
Time After: 0.01447 seconds
Time Before: 0.01743 seconds
Time After: 0.01892 seconds
Time Before: 0.01352 seconds
Time After: 0.01911 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02446 seconds
Time After: 0.02461 seconds
Time Before: 0.02637 seconds
Time After: 0.02759 seconds
End call of global.php: 0.029323816299438
Time Before: 0.03060 seconds
Time After: 0.03079 seconds
Time Before: 0.03405 seconds
Time After: 0.03553 seconds
SET lastactivity = 1789055257, location = '/forums/private.php?do=newpm&explain=1&u=26520'
Time Before: 0.05135 seconds
Time After: 0.05170 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.050381898880005 seconds with 9 queries, spending 0.0093755722045898 doing MySQL queries and 0.041006326675415 doing PHP things.
