Time Before: 0.00865 seconds
Time After: 0.01141 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01153 seconds
Time After: 0.01195 seconds
Time Before: 0.01220 seconds
Time After: 0.01257 seconds
Time Before: 0.01342 seconds
Time After: 0.01596 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01263 seconds
Time After: 0.02013 seconds
Time Taken: 0.00750 seconds
Time Before: 0.02534 seconds
Time After: 0.02572 seconds
Time Before: 0.02857 seconds
Time After: 0.02973 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02462 seconds
Time After: 0.02998 seconds
Time Taken: 0.00535 seconds
Memory After: 2,261.719 KB
Time Before: 0.04660 seconds
Time After: 0.04675 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05641 seconds
Time After: 0.05778 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.06369 seconds
Time After: 0.06394 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06692 seconds
Time After: 0.06838 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=26530' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08628 seconds
Time After: 0.08654 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
