Time Before: 0.03414 seconds
Time After: 0.04610 seconds
Time Taken: 0.01196 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.04621 seconds
Time After: 0.04749 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.04767 seconds
Time After: 0.04783 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.04867 seconds
Time After: 0.05132 seconds
Time Taken: 0.00265 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.04790 seconds
Time After: 0.05596 seconds
Time Taken: 0.00806 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.06725 seconds
Time After: 0.06765 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.07077 seconds
Time After: 0.07262 seconds
Time Taken: 0.00185 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.06653 seconds
Time After: 0.07282 seconds
Time Taken: 0.00629 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.11117 seconds
Time After: 0.11129 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.14054 seconds
Time After: 0.14182 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.14410901069641
Time Before: 0.15767 seconds
Time After: 0.15781 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.16096 seconds
Time After: 0.16241 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788954534, location = '/forums/private.php?do=newpm&explain=1&u=26543'
Time Before: 0.18517 seconds
Time After: 0.18544 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.18400812149048 seconds with 9 queries, spending 0.0095939636230469 doing MySQL queries and 0.17441415786743 doing PHP things.
