Time Before: 0.01163 seconds
Time After: 0.01554 seconds
Time Taken: 0.00391 seconds
Time Before: 0.01563 seconds
Time After: 0.01619 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01645 seconds
Time After: 0.01665 seconds
Time Before: 0.01759 seconds
Time After: 0.01986 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01674 seconds
Time After: 0.02389 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03005 seconds
Time After: 0.03043 seconds
Time Before: 0.03338 seconds
Time After: 0.03458 seconds
Time Before: 0.02942 seconds
Time After: 0.03479 seconds
Time Taken: 0.00538 seconds
Time Before: 0.05411 seconds
Time After: 0.05424 seconds
Time Before: 0.06372 seconds
Time After: 0.06493 seconds
End call of global.php: 0.066936016082764
Time Before: 0.07112 seconds
Time After: 0.07127 seconds
Time Before: 0.07363 seconds
Time After: 0.07522 seconds
Time Taken: 0.00159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=26558'
Time Before: 0.09183 seconds
Time After: 0.09211 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.090813875198364 seconds with 9 queries, spending 0.0079996585845947 doing MySQL queries and 0.08281421661377 doing PHP things.
