Time Before: 0.01230 seconds
Time After: 0.01510 seconds
Time Taken: 0.00279 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01518 seconds
Time After: 0.01556 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01583 seconds
Time After: 0.01595 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01683 seconds
Time After: 0.02062 seconds
Time Taken: 0.00378 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01600 seconds
Time After: 0.02466 seconds
Time Taken: 0.00866 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.03083 seconds
Time After: 0.03129 seconds
Time Before: 0.03447 seconds
Time After: 0.03564 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03001 seconds
Time After: 0.03585 seconds
Time Taken: 0.00584 seconds
Memory After: 2,261.719 KB
Memory Used: 132.781 KB
Time Before: 0.06827 seconds
Time After: 0.06847 seconds
Memory Before: 2,815.234 KB
Memory After: 2,815.750 KB
Time Before: 0.07904 seconds
Time After: 0.08031 seconds
Memory Before: 2,903.531 KB
Memory After: 2,904.125 KB
Time Before: 0.08896 seconds
Time After: 0.08912 seconds
Memory Before: 3,540.305 KB
Memory After: 3,540.734 KB
Time Before: 0.09207 seconds
Time After: 0.09356 seconds
Memory Before: 3,821.836 KB
Memory After: 3,823.523 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=26565' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.11250 seconds
Time After: 0.11279 seconds
Memory Before: 4,295.398 KB
Memory After: 4,295.641 KB
