Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00236 seconds
Time Before: 0.00254 seconds
Time After: 0.00265 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00326 seconds
Time After: 0.00565 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00269 seconds
Time After: 0.01094 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01312 seconds
Time After: 0.01354 seconds
Time Before: 0.01649 seconds
Time After: 0.01798 seconds
Time Before: 0.01251 seconds
Time After: 0.01825 seconds
Time Taken: 0.00574 seconds
Time Before: 0.02530 seconds
Time After: 0.02544 seconds
Time Before: 0.02769 seconds
Time After: 0.02892 seconds
End call of global.php: 0.031538963317871
Time Before: 0.03325 seconds
Time After: 0.03340 seconds
Time Before: 0.03681 seconds
Time After: 0.03829 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=26577'
Time Before: 0.05129 seconds
Time After: 0.05167 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050382137298584 seconds with 9 queries, spending 0.0081582069396973 doing MySQL queries and 0.042223930358887 doing PHP things.
