Time Before: 0.01038 seconds
Time After: 0.01733 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01743 seconds
Time After: 0.01790 seconds
Time Before: 0.01817 seconds
Time After: 0.01834 seconds
Time Before: 0.01909 seconds
Time After: 0.02171 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01840 seconds
Time After: 0.02707 seconds
Time Taken: 0.00867 seconds
Time Before: 0.03449 seconds
Time After: 0.03474 seconds
Time Before: 0.03726 seconds
Time After: 0.03855 seconds
Time Before: 0.03368 seconds
Time After: 0.03882 seconds
Time Taken: 0.00515 seconds
Time Before: 0.05972 seconds
Time After: 0.05989 seconds
Time Before: 0.07300 seconds
Time After: 0.07427 seconds
Time Before: 0.08107 seconds
Time After: 0.08123 seconds
Time Before: 0.08370 seconds
Time After: 0.08513 seconds
UPDATE session SET lastactivity = 1776532018, location = '/forums/private.php?do=newpm&explain=1&u=26595', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.10561 seconds
Time After: 0.10592 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
