Time Before: 0.02139 seconds
Time After: 0.02846 seconds
Time Taken: 0.00707 seconds
Time Before: 0.02854 seconds
Time After: 0.03118 seconds
Time Taken: 0.00264 seconds
Time Before: 0.03144 seconds
Time After: 0.03157 seconds
Time Before: 0.03234 seconds
Time After: 0.03504 seconds
Time Taken: 0.00270 seconds
Time Before: 0.03164 seconds
Time After: 0.03933 seconds
Time Taken: 0.00770 seconds
Time Before: 0.04664 seconds
Time After: 0.04703 seconds
Time Before: 0.04960 seconds
Time After: 0.05077 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04598 seconds
Time After: 0.05098 seconds
Time Taken: 0.00500 seconds
Memory After: 2,261.836 KB
Time Before: 0.07551 seconds
Time After: 0.07566 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08669 seconds
Time After: 0.08868 seconds
Time Taken: 0.00199 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.090579986572266
Time Before: 0.09667 seconds
Time After: 0.09681 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09935 seconds
Time After: 0.10196 seconds
Time Taken: 0.00261 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789129827, location = '/forums/private.php?do=newpm&explain=1&u=26611'
Time Before: 0.11841 seconds
Time After: 0.11879 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.11747002601624 seconds with 9 queries, spending 0.012293100357056 doing MySQL queries and 0.10517692565918 doing PHP things.
