Time Before: 0.01057 seconds
Time After: 0.01501 seconds
Time Taken: 0.00444 seconds
Time Before: 0.01513 seconds
Time After: 0.01586 seconds
Time Taken: 0.00073 seconds
Time Before: 0.01612 seconds
Time After: 0.01627 seconds
Time Before: 0.01704 seconds
Time After: 0.01965 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01633 seconds
Time After: 0.02349 seconds
Time Taken: 0.00717 seconds
Time Before: 0.02897 seconds
Time After: 0.02943 seconds
Time Before: 0.03097 seconds
Time After: 0.03226 seconds
Time Before: 0.02824 seconds
Time After: 0.03251 seconds
Time Taken: 0.00427 seconds
Time Before: 0.05992 seconds
Time After: 0.06007 seconds
Time Before: 0.07322 seconds
Time After: 0.07450 seconds
Time Before: 0.08136 seconds
Time After: 0.08157 seconds
Time Before: 0.08446 seconds
Time After: 0.08589 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=26761' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.10068 seconds
Time After: 0.10099 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
