Time Before: 0.00137 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00326 seconds
Time Taken: 0.00139 seconds
Time Before: 0.00362 seconds
Time After: 0.00382 seconds
Time Before: 0.00460 seconds
Time After: 0.00714 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00389 seconds
Time After: 0.01061 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01292 seconds
Time After: 0.01342 seconds
Time Before: 0.01635 seconds
Time After: 0.01774 seconds
Time Before: 0.01187 seconds
Time After: 0.01794 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02360 seconds
Time After: 0.02439 seconds
Time Taken: 0.00079 seconds
Time Before: 0.02756 seconds
Time After: 0.02887 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03182 seconds
Time After: 0.03197 seconds
Time Before: 0.03417 seconds
Time After: 0.03560 seconds
UPDATE session SET lastactivity = 1789070073, location = '/forums/private.php?do=newpm&explain=1&u=26767' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05072 seconds
Time After: 0.05128 seconds
Time Taken: 0.00057 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
