Time Before: 0.02808 seconds
Time After: 0.03300 seconds
Time Taken: 0.00491 seconds
Time Before: 0.03311 seconds
Time After: 0.03363 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03390 seconds
Time After: 0.03409 seconds
Time Before: 0.03488 seconds
Time After: 0.03697 seconds
Time Taken: 0.00209 seconds
Time Before: 0.03417 seconds
Time After: 0.04121 seconds
Time Taken: 0.00704 seconds
Time Before: 0.04933 seconds
Time After: 0.04975 seconds
Time Before: 0.05239 seconds
Time After: 0.05363 seconds
Time Before: 0.04857 seconds
Time After: 0.05387 seconds
Time Taken: 0.00530 seconds
Time Before: 0.09968 seconds
Time After: 0.09982 seconds
Time Before: 0.11973 seconds
Time After: 0.12097 seconds
Time Before: 0.13580 seconds
Time After: 0.13659 seconds
Time Taken: 0.00079 seconds
Time Before: 0.13965 seconds
Time After: 0.14155 seconds
Time Taken: 0.00190 seconds
UPDATE session SET lastactivity = 1776819455, location = '/forums/private.php?do=newpm&explain=1&u=26770' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.16141 seconds
Time After: 0.16217 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
