Time Before: 0.00140 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00235 seconds
Time Before: 0.00258 seconds
Time After: 0.00272 seconds
Time Before: 0.00360 seconds
Time After: 0.00638 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00276 seconds
Time After: 0.01061 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01258 seconds
Time After: 0.01314 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01587 seconds
Time After: 0.01713 seconds
Time Before: 0.01178 seconds
Time After: 0.01736 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02362 seconds
Time After: 0.02386 seconds
Time Before: 0.02604 seconds
Time After: 0.02733 seconds
End call of global.php: 0.029896020889282
Time Before: 0.03126 seconds
Time After: 0.03149 seconds
Time Before: 0.03472 seconds
Time After: 0.03617 seconds
SET lastactivity = 1788883466, location = '/forums/private.php?do=newpm&explain=1&u=26799'
Time Before: 0.05034 seconds
Time After: 0.05090 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049407005310059 seconds with 9 queries, spending 0.0089750289916992 doing MySQL queries and 0.040431976318359 doing PHP things.
