Time Before: 0.00161 seconds
Time After: 0.00216 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00223 seconds
Time After: 0.00281 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00301 seconds
Time After: 0.00312 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00380 seconds
Time After: 0.00653 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00317 seconds
Time After: 0.01001 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01194 seconds
Time After: 0.01250 seconds
Time Before: 0.01525 seconds
Time After: 0.01658 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01125 seconds
Time After: 0.01679 seconds
Time Taken: 0.00554 seconds
Memory After: 2,261.719 KB
Time Before: 0.02233 seconds
Time After: 0.02255 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02461 seconds
Time After: 0.02585 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.02897 seconds
Time After: 0.02919 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03120 seconds
Time After: 0.03281 seconds
Time Taken: 0.00161 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=26857' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04502 seconds
Time After: 0.04542 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
