Time Before: 0.00867 seconds
Time After: 0.01109 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01125 seconds
Time After: 0.01174 seconds
Time Before: 0.01195 seconds
Time After: 0.01207 seconds
Time Before: 0.01289 seconds
Time After: 0.01532 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01212 seconds
Time After: 0.01936 seconds
Time Taken: 0.00724 seconds
Time Before: 0.02340 seconds
Time After: 0.02388 seconds
Time Before: 0.02523 seconds
Time After: 0.02647 seconds
Time Before: 0.02272 seconds
Time After: 0.02666 seconds
Time Taken: 0.00395 seconds
Time Before: 0.05189 seconds
Time After: 0.05205 seconds
Time Before: 0.06210 seconds
Time After: 0.06335 seconds
End call of global.php: 0.065584897994995
Time Before: 0.06941 seconds
Time After: 0.06960 seconds
Time Before: 0.07267 seconds
Time After: 0.07413 seconds
SET lastactivity = 1785420167, location = '/forums/private.php?do=newpm&explain=1&u=2700'
Time Before: 0.09416 seconds
Time After: 0.09449 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.092690944671631 seconds with 9 queries, spending 0.0081534385681152 doing MySQL queries and 0.084537506103516 doing PHP things.
