Time Before: 0.01992 seconds
Time After: 0.02741 seconds
Time Taken: 0.00748 seconds
Time Before: 0.02750 seconds
Time After: 0.02788 seconds
Time Before: 0.02811 seconds
Time After: 0.02823 seconds
Time Before: 0.02895 seconds
Time After: 0.03134 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02830 seconds
Time After: 0.03562 seconds
Time Taken: 0.00732 seconds
Time Before: 0.04625 seconds
Time After: 0.04656 seconds
Time Before: 0.04785 seconds
Time After: 0.04911 seconds
Time Before: 0.04557 seconds
Time After: 0.04937 seconds
Time Taken: 0.00380 seconds
Time Before: 0.07679 seconds
Time After: 0.07695 seconds
Time Before: 0.09783 seconds
Time After: 0.09907 seconds
Time Before: 0.11429 seconds
Time After: 0.11441 seconds
Time Before: 0.11710 seconds
Time After: 0.11858 seconds
UPDATE session SET lastactivity = 1776573628, location = '/forums/private.php?do=newpm&explain=1&u=27008', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.13717 seconds
Time After: 0.13742 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
