Time Before: 0.00531 seconds
Time After: 0.00929 seconds
Time Taken: 0.00398 seconds
Time Before: 0.00936 seconds
Time After: 0.00979 seconds
Time Before: 0.01005 seconds
Time After: 0.01021 seconds
Time Before: 0.01092 seconds
Time After: 0.01367 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01028 seconds
Time After: 0.01787 seconds
Time Taken: 0.00759 seconds
Time Before: 0.02531 seconds
Time After: 0.02577 seconds
Time Before: 0.02822 seconds
Time After: 0.02944 seconds
Time Before: 0.02472 seconds
Time After: 0.02970 seconds
Time Taken: 0.00498 seconds
Time Before: 0.04708 seconds
Time After: 0.04724 seconds
Time Before: 0.06248 seconds
Time After: 0.06372 seconds
End call of global.php: 0.065927982330322
Time Before: 0.07264 seconds
Time After: 0.07288 seconds
Time Before: 0.07551 seconds
Time After: 0.07693 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=27020'
Time Before: 0.09398 seconds
Time After: 0.09434 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.092885971069336 seconds with 9 queries, spending 0.0084333419799805 doing MySQL queries and 0.084452629089355 doing PHP things.
