Time Before: 0.00204 seconds
Time After: 0.00267 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00278 seconds
Time After: 0.00327 seconds
Time Before: 0.00349 seconds
Time After: 0.00361 seconds
Time Before: 0.00450 seconds
Time After: 0.00703 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00369 seconds
Time After: 0.01117 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01317 seconds
Time After: 0.01354 seconds
Time Before: 0.01587 seconds
Time After: 0.01705 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01255 seconds
Time After: 0.01723 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02244 seconds
Time After: 0.02262 seconds
Time Before: 0.02501 seconds
Time After: 0.02623 seconds
End call of global.php: 0.02801513671875
Time Before: 0.02910 seconds
Time After: 0.02922 seconds
Time Before: 0.03117 seconds
Time After: 0.03258 seconds
SET lastactivity = 1776640641, location = '/forums/private.php?do=newpm&explain=1&u=27078', badlocation = 1
Time Before: 0.04600 seconds
Time After: 0.04628 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.045096158981323 seconds with 9 queries, spending 0.0079247951507568 doing MySQL queries and 0.037171363830566 doing PHP things.
