Time Before: 0.01067 seconds
Time After: 0.01395 seconds
Time Taken: 0.00329 seconds
Time Before: 0.01405 seconds
Time After: 0.01457 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01486 seconds
Time After: 0.01505 seconds
Time Before: 0.01579 seconds
Time After: 0.01820 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01512 seconds
Time After: 0.02228 seconds
Time Taken: 0.00717 seconds
Time Before: 0.02670 seconds
Time After: 0.02707 seconds
Time Before: 0.02845 seconds
Time After: 0.02966 seconds
Time Before: 0.02606 seconds
Time After: 0.02989 seconds
Time Taken: 0.00383 seconds
Time Before: 0.04636 seconds
Time After: 0.04655 seconds
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"21.63,\";s:9:\"lastcheck\";i:1788962545;}', 1)
Time Before: 0.05835 seconds
Time After: 0.05869 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.06964 seconds
Time After: 0.07097 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
End call of global.php: 0.073400974273682
Time Before: 0.07819 seconds
Time After: 0.07837 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.08096 seconds
Time After: 0.08252 seconds
Time Taken: 0.00156 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
SET lastactivity = 1788962545, location = '/forums/private.php?do=newpm&explain=1&u=27120'
Time Before: 0.10170 seconds
Time After: 0.10202 seconds
Memory Before: 4,919.750 KB
Memory After: 4,919.977 KB
Page generated in 0.10050582885742 seconds with 10 queries, spending 0.0086219310760498 doing MySQL queries and 0.091883897781372 doing PHP things.
