Time Before: 0.02246 seconds
Time After: 0.03237 seconds
Time Taken: 0.00991 seconds
Time Before: 0.03255 seconds
Time After: 0.03312 seconds
Time Taken: 0.00057 seconds
Time Before: 0.03343 seconds
Time After: 0.03360 seconds
Time Before: 0.03443 seconds
Time After: 0.03648 seconds
Time Taken: 0.00205 seconds
Time Before: 0.03367 seconds
Time After: 0.04110 seconds
Time Taken: 0.00742 seconds
Time Before: 0.05410 seconds
Time After: 0.05456 seconds
Time Before: 0.05611 seconds
Time After: 0.05735 seconds
Time Before: 0.05321 seconds
Time After: 0.05761 seconds
Time Taken: 0.00440 seconds
Time Before: 0.10617 seconds
Time After: 0.10631 seconds
Time Before: 0.13406 seconds
Time After: 0.13529 seconds
Time Before: 0.15073 seconds
Time After: 0.15089 seconds
Time Before: 0.15349 seconds
Time After: 0.15548 seconds
Time Taken: 0.00200 seconds
UPDATE session SET lastactivity = 1785301690, location = '/forums/private.php?do=newpm&explain=1&u=27153', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.17396 seconds
Time After: 0.17428 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
