Time Before: 0.02327 seconds
Time After: 0.03213 seconds
Time Taken: 0.00886 seconds
Time Before: 0.03224 seconds
Time After: 0.03260 seconds
Time Before: 0.03281 seconds
Time After: 0.03297 seconds
Time Before: 0.03383 seconds
Time After: 0.03661 seconds
Time Taken: 0.00278 seconds
Time Before: 0.03304 seconds
Time After: 0.04108 seconds
Time Taken: 0.00804 seconds
Time Before: 0.05234 seconds
Time After: 0.05271 seconds
Time Before: 0.05526 seconds
Time After: 0.05645 seconds
Time Before: 0.05167 seconds
Time After: 0.05671 seconds
Time Taken: 0.00504 seconds
Time Before: 0.08744 seconds
Time After: 0.08758 seconds
Time Before: 0.10719 seconds
Time After: 0.10846 seconds
Time Before: 0.12596 seconds
Time After: 0.12611 seconds
Time Before: 0.12935 seconds
Time After: 0.13087 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1776615384, location = '/forums/private.php?do=newpm&explain=1&u=27234' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14991 seconds
Time After: 0.15021 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
