Time Before: 0.01205 seconds
Time After: 0.01823 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01833 seconds
Time After: 0.01872 seconds
Time Before: 0.01894 seconds
Time After: 0.01913 seconds
Time Before: 0.01997 seconds
Time After: 0.02218 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01919 seconds
Time After: 0.02687 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03298 seconds
Time After: 0.03341 seconds
Time Before: 0.03499 seconds
Time After: 0.03620 seconds
Time Before: 0.03217 seconds
Time After: 0.03639 seconds
Time Taken: 0.00422 seconds
Time Before: 0.05812 seconds
Time After: 0.05827 seconds
Time Before: 0.06851 seconds
Time After: 0.06974 seconds
Time Before: 0.07617 seconds
Time After: 0.07634 seconds
Time Before: 0.07865 seconds
Time After: 0.08009 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=27269' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.09617 seconds
Time After: 0.09655 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
