Time Before: 0.02333 seconds
Time After: 0.03001 seconds
Time Taken: 0.00667 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03014 seconds
Time After: 0.03058 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03088 seconds
Time After: 0.03101 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03189 seconds
Time After: 0.03455 seconds
Time Taken: 0.00266 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03106 seconds
Time After: 0.03888 seconds
Time Taken: 0.00782 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.04848 seconds
Time After: 0.04905 seconds
Time Taken: 0.00058 seconds
Time Before: 0.05077 seconds
Time After: 0.05201 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04747 seconds
Time After: 0.05225 seconds
Time Taken: 0.00478 seconds
Memory After: 2,261.703 KB
Time Before: 0.09031 seconds
Time After: 0.09049 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.10790 seconds
Time After: 0.10914 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.11155104637146
Time Before: 0.11969 seconds
Time After: 0.12013 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.12244 seconds
Time After: 0.12445 seconds
Time Taken: 0.00202 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=27282', badlocation = 1
Time Before: 0.14162 seconds
Time After: 0.14202 seconds
Memory Before: 4,295.766 KB
Memory After: 4,295.992 KB
Page generated in 0.1404869556427 seconds with 9 queries, spending 0.0093131065368652 doing MySQL queries and 0.13117384910583 doing PHP things.
