Time Before: 0.02031 seconds
Time After: 0.02667 seconds
Time Taken: 0.00636 seconds
Time Before: 0.02677 seconds
Time After: 0.02717 seconds
Time Before: 0.02740 seconds
Time After: 0.02753 seconds
Time Before: 0.02829 seconds
Time After: 0.03052 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02760 seconds
Time After: 0.03453 seconds
Time Taken: 0.00693 seconds
Time Before: 0.04545 seconds
Time After: 0.04592 seconds
Time Before: 0.04839 seconds
Time After: 0.04956 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04476 seconds
Time After: 0.04974 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.836 KB
Time Before: 0.07926 seconds
Time After: 0.07965 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09663 seconds
Time After: 0.09786 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.099778175354004
Time Before: 0.10731 seconds
Time After: 0.10748 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11002 seconds
Time After: 0.11201 seconds
Time Taken: 0.00199 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789072759, location = '/forums/private.php?do=newpm&explain=1&u=2731'
Time Before: 0.13133 seconds
Time After: 0.13180 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
Page generated in 0.13025498390198 seconds with 9 queries, spending 0.0086369514465332 doing MySQL queries and 0.12161803245544 doing PHP things.
