Time Before: 0.00144 seconds
Time After: 0.00192 seconds
Time Before: 0.00198 seconds
Time After: 0.00248 seconds
Time Before: 0.00283 seconds
Time After: 0.00330 seconds
Time Before: 0.00428 seconds
Time After: 0.00714 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00338 seconds
Time After: 0.01198 seconds
Time Taken: 0.00860 seconds
Time Before: 0.01479 seconds
Time After: 0.01523 seconds
Time Before: 0.01856 seconds
Time After: 0.01989 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01398 seconds
Time After: 0.02013 seconds
Time Taken: 0.00615 seconds
Time Before: 0.02656 seconds
Time After: 0.02669 seconds
Time Before: 0.02859 seconds
Time After: 0.02987 seconds
Time Before: 0.03359 seconds
Time After: 0.03376 seconds
Time Before: 0.03601 seconds
Time After: 0.03751 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1789066114, location = '/forums/private.php?do=newpm&explain=1&u=27345', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05118 seconds
Time After: 0.05184 seconds
Time Taken: 0.00067 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
