Time Before: 0.00353 seconds
Time After: 0.00471 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00481 seconds
Time After: 0.00534 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00566 seconds
Time After: 0.00581 seconds
Time Before: 0.00665 seconds
Time After: 0.01059 seconds
Time Taken: 0.00393 seconds
Time Before: 0.00588 seconds
Time After: 0.01548 seconds
Time Taken: 0.00959 seconds
Time Before: 0.01746 seconds
Time After: 0.01783 seconds
Time Before: 0.02070 seconds
Time After: 0.02232 seconds
Time Taken: 0.00161 seconds
Time Before: 0.01683 seconds
Time After: 0.02258 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02900 seconds
Time After: 0.02912 seconds
Time Before: 0.03104 seconds
Time After: 0.03251 seconds
Time Before: 0.03666 seconds
Time After: 0.03684 seconds
Time Before: 0.03919 seconds
Time After: 0.04080 seconds
UPDATE session SET lastactivity = 1788972854, location = '/forums/private.php?do=newpm&explain=1&u=27414' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06081 seconds
Time After: 0.06113 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
