Time Before: 0.03594 seconds
Time After: 0.04971 seconds
Time Taken: 0.01378 seconds
Time Before: 0.04984 seconds
Time After: 0.05052 seconds
Time Taken: 0.00069 seconds
Time Before: 0.05078 seconds
Time After: 0.05093 seconds
Time Before: 0.05168 seconds
Time After: 0.05363 seconds
Time Taken: 0.00194 seconds
Time Before: 0.05100 seconds
Time After: 0.05759 seconds
Time Taken: 0.00659 seconds
Time Before: 0.07328 seconds
Time After: 0.07363 seconds
Time Before: 0.07610 seconds
Time After: 0.07727 seconds
Time Taken: 0.00118 seconds
Time Before: 0.07241 seconds
Time After: 0.07749 seconds
Time Taken: 0.00508 seconds
Time Before: 0.14495 seconds
Time After: 0.14510 seconds
Time Before: 0.17487 seconds
Time After: 0.17620 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.17906403541565
Time Before: 0.19395 seconds
Time After: 0.19432 seconds
Time Before: 0.19711 seconds
Time After: 0.19855 seconds
SET lastactivity = 1783256177, location = '/forums/private.php?do=newpm&explain=1&u=27420', badlocation = 1
Time Before: 0.21837 seconds
Time After: 0.21870 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.21694612503052 seconds with 9 queries, spending 0.0079348087310791 doing MySQL queries and 0.20901131629944 doing PHP things.
