Time Before: 0.01336 seconds
Time After: 0.01883 seconds
Time Taken: 0.00547 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01892 seconds
Time After: 0.01985 seconds
Time Taken: 0.00092 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02027 seconds
Time After: 0.02069 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02153 seconds
Time After: 0.02401 seconds
Time Taken: 0.00248 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02077 seconds
Time After: 0.02862 seconds
Time Taken: 0.00785 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03518 seconds
Time After: 0.03577 seconds
Time Taken: 0.00060 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03840 seconds
Time After: 0.03962 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.03453 seconds
Time After: 0.03983 seconds
Time Taken: 0.00530 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.05970 seconds
Time After: 0.05994 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.08519 seconds
Time After: 0.08653 seconds
Time Taken: 0.00134 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.089377164840698
Time Before: 0.10853 seconds
Time After: 0.10870 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.11318 seconds
Time After: 0.11464 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1773292004, location = '/forums/private.php?do=newpm&explain=1&u=27465'
Time Before: 0.13615 seconds
Time After: 0.13655 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.13513803482056 seconds with 9 queries, spending 0.0092558860778809 doing MySQL queries and 0.12588214874268 doing PHP things.
