Time Before: 0.01087 seconds
Time After: 0.01426 seconds
Time Taken: 0.00339 seconds
Time Before: 0.01437 seconds
Time After: 0.01499 seconds
Time Taken: 0.00062 seconds
Time Before: 0.01530 seconds
Time After: 0.01552 seconds
Time Before: 0.01632 seconds
Time After: 0.01974 seconds
Time Taken: 0.00343 seconds
Time Before: 0.01559 seconds
Time After: 0.02377 seconds
Time Taken: 0.00818 seconds
Time Before: 0.02950 seconds
Time After: 0.03023 seconds
Time Taken: 0.00073 seconds
Time Before: 0.03292 seconds
Time After: 0.03409 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02879 seconds
Time After: 0.03429 seconds
Time Taken: 0.00550 seconds
Memory After: 2,261.836 KB
Time Before: 0.04894 seconds
Time After: 0.04909 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06114 seconds
Time After: 0.06236 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.064403057098389
Time Before: 0.07250 seconds
Time After: 0.07264 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07499 seconds
Time After: 0.07642 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789139777, location = '/forums/private.php?do=newpm&explain=1&u=27595', badlocation = 1
Time Before: 0.09318 seconds
Time After: 0.09355 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.092068195343018 seconds with 9 queries, spending 0.0094642639160156 doing MySQL queries and 0.082603931427002 doing PHP things.
