Time Before: 0.02288 seconds
Time After: 0.03024 seconds
Time Taken: 0.00737 seconds
Time Before: 0.03035 seconds
Time After: 0.03216 seconds
Time Taken: 0.00181 seconds
Time Before: 0.03244 seconds
Time After: 0.03262 seconds
Time Before: 0.03347 seconds
Time After: 0.03609 seconds
Time Taken: 0.00262 seconds
Time Before: 0.03270 seconds
Time After: 0.04011 seconds
Time Taken: 0.00742 seconds
Time Before: 0.04713 seconds
Time After: 0.04753 seconds
Time Before: 0.05007 seconds
Time After: 0.05128 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04649 seconds
Time After: 0.05148 seconds
Time Taken: 0.00500 seconds
Memory After: 2,261.719 KB
Time Before: 0.09850 seconds
Time After: 0.09865 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11593 seconds
Time After: 0.11744 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11968994140625
Time Before: 0.12641 seconds
Time After: 0.12663 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12896 seconds
Time After: 0.13047 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=27720'
Time Before: 0.14837 seconds
Time After: 0.14859 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.14733600616455 seconds with 9 queries, spending 0.0098328590393066 doing MySQL queries and 0.13750314712524 doing PHP things.
