Time Before: 0.00290 seconds
Time After: 0.00340 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00348 seconds
Time After: 0.00413 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00437 seconds
Time After: 0.00449 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00537 seconds
Time After: 0.00896 seconds
Time Taken: 0.00359 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00454 seconds
Time After: 0.01240 seconds
Time Taken: 0.00786 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01443 seconds
Time After: 0.01468 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01778 seconds
Time After: 0.01903 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01373 seconds
Time After: 0.01922 seconds
Time Taken: 0.00549 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02561 seconds
Time After: 0.02573 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03481 seconds
Time After: 0.03609 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.038855075836182
Time Before: 0.04584 seconds
Time After: 0.04617 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04942 seconds
Time After: 0.05084 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772951903, location = '/forums/private.php?do=newpm&explain=1&u=27724'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06499 seconds
Time After: 0.06532 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.064057111740112 seconds with 9 queries, spending 0.009345531463623 doing MySQL queries and 0.054711580276489 doing PHP things.
