Time Before: 0.00564 seconds
Time After: 0.00725 seconds
Time Taken: 0.00160 seconds
Time Before: 0.00737 seconds
Time After: 0.00800 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00836 seconds
Time After: 0.00856 seconds
Time Before: 0.00931 seconds
Time After: 0.01172 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00863 seconds
Time After: 0.01621 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01945 seconds
Time After: 0.01991 seconds
Time Before: 0.02291 seconds
Time After: 0.02419 seconds
Time Before: 0.01873 seconds
Time After: 0.02443 seconds
Time Taken: 0.00569 seconds
Time Before: 0.04123 seconds
Time After: 0.04142 seconds
Time Before: 0.04798 seconds
Time After: 0.04927 seconds
End call of global.php: 0.052479982376099
Time Before: 0.05585 seconds
Time After: 0.05603 seconds
Time Before: 0.05926 seconds
Time After: 0.06082 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1784763475, location = '/forums/private.php?do=newpm&explain=1&u=27732'
Time Before: 0.07977 seconds
Time After: 0.08015 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.078788995742798 seconds with 9 queries, spending 0.008575439453125 doing MySQL queries and 0.070213556289673 doing PHP things.
