Time Before: 0.01694 seconds
Time After: 0.02203 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02213 seconds
Time After: 0.02267 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02289 seconds
Time After: 0.02301 seconds
Time Before: 0.02382 seconds
Time After: 0.02648 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02307 seconds
Time After: 0.03097 seconds
Time Taken: 0.00789 seconds
Time Before: 0.03585 seconds
Time After: 0.03628 seconds
Time Before: 0.03864 seconds
Time After: 0.03985 seconds
Time Before: 0.03511 seconds
Time After: 0.04009 seconds
Time Taken: 0.00498 seconds
Time Before: 0.06401 seconds
Time After: 0.06420 seconds
Time Before: 0.08008 seconds
Time After: 0.08133 seconds
End call of global.php: 0.083723068237305
Time Before: 0.09063 seconds
Time After: 0.09081 seconds
Time Before: 0.09345 seconds
Time After: 0.09525 seconds
Time Taken: 0.00180 seconds
SET lastactivity = 1777034246, location = '/forums/private.php?do=newpm&explain=1&u=27753'
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.11380 seconds
Time After: 0.11422 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.11258292198181 seconds with 9 queries, spending 0.0088090896606445 doing MySQL queries and 0.10377383232117 doing PHP things.
