Time Before: 0.02311 seconds
Time After: 0.02892 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02903 seconds
Time After: 0.02952 seconds
Time Before: 0.02978 seconds
Time After: 0.03009 seconds
Time Before: 0.03105 seconds
Time After: 0.03458 seconds
Time Taken: 0.00353 seconds
Time Before: 0.03016 seconds
Time After: 0.03875 seconds
Time Taken: 0.00859 seconds
Time Before: 0.04488 seconds
Time After: 0.04537 seconds
Time Before: 0.04817 seconds
Time After: 0.04952 seconds
Time Taken: 0.00136 seconds
Time Before: 0.04413 seconds
Time After: 0.04975 seconds
Time Taken: 0.00562 seconds
Time Before: 0.09033 seconds
Time After: 0.09050 seconds
Time Before: 0.10457 seconds
Time After: 0.10583 seconds
Time Before: 0.11715 seconds
Time After: 0.11731 seconds
Time Before: 0.11992 seconds
Time After: 0.12137 seconds
UPDATE session SET lastactivity = 1785322108, location = '/forums/private.php?do=newpm&explain=1&u=27767', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.14130 seconds
Time After: 0.14161 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
