Time Before: 0.01943 seconds
Time After: 0.02360 seconds
Time Taken: 0.00417 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02369 seconds
Time After: 0.02410 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02433 seconds
Time After: 0.02447 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02536 seconds
Time After: 0.02768 seconds
Time Taken: 0.00232 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02454 seconds
Time After: 0.03228 seconds
Time Taken: 0.00773 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04123 seconds
Time After: 0.04190 seconds
Time Taken: 0.00066 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04350 seconds
Time After: 0.04467 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04042 seconds
Time After: 0.04493 seconds
Time Taken: 0.00451 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.08226 seconds
Time After: 0.08241 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.41519 seconds
Time After: 0.41697 seconds
Time Taken: 0.00178 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.41918992996216
Time Before: 0.44703 seconds
Time After: 0.44721 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.45467 seconds
Time After: 0.45728 seconds
Time Taken: 0.00260 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772906869, location = '/forums/private.php?do=newpm&explain=1&u=27877', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.48756 seconds
Time After: 0.48790 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.48651695251465 seconds with 9 queries, spending 0.0097577571868896 doing MySQL queries and 0.47675919532776 doing PHP things.
