Time Before: 0.00158 seconds
Time After: 0.00215 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00222 seconds
Time After: 0.00295 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00324 seconds
Time After: 0.00341 seconds
Time Before: 0.00412 seconds
Time After: 0.00716 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00346 seconds
Time After: 0.01058 seconds
Time Taken: 0.00712 seconds
Time Before: 0.01237 seconds
Time After: 0.01257 seconds
Time Before: 0.01506 seconds
Time After: 0.01625 seconds
Time Before: 0.01177 seconds
Time After: 0.01642 seconds
Time Taken: 0.00466 seconds
Time Before: 0.02146 seconds
Time After: 0.02161 seconds
Time Before: 0.02361 seconds
Time After: 0.02492 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.026622772216797
Time Before: 0.02795 seconds
Time After: 0.02811 seconds
Time Before: 0.03016 seconds
Time After: 0.03163 seconds
SET lastactivity = 1784790551, location = '/forums/private.php?do=newpm&explain=1&u=27894', badlocation = 1
Time Before: 0.04441 seconds
Time After: 0.04476 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.043434858322144 seconds with 9 queries, spending 0.0087735652923584 doing MySQL queries and 0.034661293029785 doing PHP things.
