Time Before: 0.00893 seconds
Time After: 0.01162 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01173 seconds
Time After: 0.01218 seconds
Time Before: 0.01239 seconds
Time After: 0.01255 seconds
Time Before: 0.01332 seconds
Time After: 0.01592 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01262 seconds
Time After: 0.01989 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02509 seconds
Time After: 0.02546 seconds
Time Before: 0.02785 seconds
Time After: 0.02907 seconds
Time Before: 0.02448 seconds
Time After: 0.02927 seconds
Time Taken: 0.00480 seconds
Time Before: 0.04724 seconds
Time After: 0.04736 seconds
Memory Before: 3,438.242 KB
Memory After: 3,438.758 KB
Time Before: 0.05485 seconds
Time After: 0.05608 seconds
End call of global.php: 0.058016061782837
Time Before: 0.06072 seconds
Time After: 0.06087 seconds
Time Before: 0.06303 seconds
Time After: 0.06450 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=279', badlocation = 1
Time Before: 0.08483 seconds
Time After: 0.08514 seconds
Memory Before: 4,911.047 KB
Memory Used: 0.234 KB
Page generated in 0.083636045455933 seconds with 9 queries, spending 0.0080897808074951 doing MySQL queries and 0.075546264648438 doing PHP things.
