Time Before: 0.00335 seconds
Time After: 0.00464 seconds
Time Before: 0.00471 seconds
Time After: 0.00508 seconds
Time Before: 0.00533 seconds
Time After: 0.00551 seconds
Time Before: 0.00616 seconds
Time After: 0.00880 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00555 seconds
Time After: 0.01224 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01490 seconds
Time After: 0.01528 seconds
Time Before: 0.01772 seconds
Time After: 0.01908 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01423 seconds
Time After: 0.01926 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02568 seconds
Time After: 0.02587 seconds
Time Before: 0.02838 seconds
Time After: 0.02964 seconds
Time Before: 0.03386 seconds
Time After: 0.03405 seconds
Time Before: 0.03671 seconds
Time After: 0.03823 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=28113', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05173 seconds
Time After: 0.05204 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
