Time Before: 0.01946 seconds
Time After: 0.02492 seconds
Time Taken: 0.00546 seconds
Time Before: 0.02504 seconds
Time After: 0.02545 seconds
Time Before: 0.02570 seconds
Time After: 0.02584 seconds
Time Before: 0.02667 seconds
Time After: 0.03080 seconds
Time Taken: 0.00413 seconds
Time Before: 0.02589 seconds
Time After: 0.03482 seconds
Time Taken: 0.00893 seconds
Time Before: 0.04392 seconds
Time After: 0.04413 seconds
Time Before: 0.04722 seconds
Time After: 0.04855 seconds
Time Taken: 0.00133 seconds
Time Before: 0.04318 seconds
Time After: 0.04877 seconds
Time Taken: 0.00559 seconds
Time Before: 0.09126 seconds
Time After: 0.09146 seconds
Time Before: 0.11414 seconds
Time After: 0.11571 seconds
Time Taken: 0.00157 seconds
Time Before: 0.12478 seconds
Time After: 0.12496 seconds
Time Before: 0.12746 seconds
Time After: 0.12888 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=28133' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14624 seconds
Time After: 0.14650 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
