Time Before: 0.01980 seconds
Time After: 0.02469 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02479 seconds
Time After: 0.02520 seconds
Time Before: 0.02543 seconds
Time After: 0.02556 seconds
Time Before: 0.02636 seconds
Time After: 0.02852 seconds
Time Taken: 0.00216 seconds
Time Before: 0.02562 seconds
Time After: 0.03267 seconds
Time Taken: 0.00705 seconds
Time Before: 0.03999 seconds
Time After: 0.04040 seconds
Time Before: 0.04294 seconds
Time After: 0.04418 seconds
Time Before: 0.03924 seconds
Time After: 0.04443 seconds
Time Taken: 0.00519 seconds
Time Before: 0.07267 seconds
Time After: 0.07281 seconds
Time Before: 0.08917 seconds
Time After: 0.09043 seconds
End call of global.php: 0.092484951019287
Time Before: 0.10035 seconds
Time After: 0.10051 seconds
Time Before: 0.10285 seconds
Time After: 0.10430 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=28226'
Time Before: 0.12310 seconds
Time After: 0.12337 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.12213587760925 seconds with 9 queries, spending 0.0076272487640381 doing MySQL queries and 0.11450862884521 doing PHP things.
