Time Before: 0.02145 seconds
Time After: 0.02788 seconds
Time Taken: 0.00643 seconds
Time Before: 0.02797 seconds
Time After: 0.02838 seconds
Time Before: 0.02869 seconds
Time After: 0.02885 seconds
Time Before: 0.02956 seconds
Time After: 0.03206 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02892 seconds
Time After: 0.03588 seconds
Time Taken: 0.00696 seconds
Time Before: 0.04557 seconds
Time After: 0.04595 seconds
Time Before: 0.04730 seconds
Time After: 0.04854 seconds
Time Before: 0.04486 seconds
Time After: 0.04878 seconds
Time Taken: 0.00392 seconds
Time Before: 0.10134 seconds
Time After: 0.10150 seconds
Time Before: 0.47098 seconds
Time After: 0.47237 seconds
Time Taken: 0.00140 seconds
Time Before: 0.48479 seconds
Time After: 0.48496 seconds
Time Before: 0.48787 seconds
Time After: 0.48935 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=28333', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.50899 seconds
Time After: 0.50932 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
