Time Before: 0.00207 seconds
Time After: 0.00270 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00280 seconds
Time After: 0.00323 seconds
Time Before: 0.00349 seconds
Time After: 0.00362 seconds
Time Before: 0.00450 seconds
Time After: 0.00673 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00369 seconds
Time After: 0.01215 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01470 seconds
Time After: 0.01509 seconds
Time Before: 0.01824 seconds
Time After: 0.01955 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01394 seconds
Time After: 0.01981 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02706 seconds
Time After: 0.02735 seconds
Time Before: 0.02931 seconds
Time After: 0.03063 seconds
End call of global.php: 0.033151865005493
Time Before: 0.03465 seconds
Time After: 0.03484 seconds
Time Before: 0.03761 seconds
Time After: 0.03911 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1785289348, location = '/forums/private.php?do=newpm&explain=1&u=28366'
Time Before: 0.05348 seconds
Time After: 0.05371 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.052109956741333 seconds with 9 queries, spending 0.0080249309539795 doing MySQL queries and 0.044085025787354 doing PHP things.
