Time Before: 0.00198 seconds
Time After: 0.00254 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00264 seconds
Time After: 0.00302 seconds
Time Before: 0.00324 seconds
Time After: 0.00342 seconds
Time Before: 0.00426 seconds
Time After: 0.00631 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00349 seconds
Time After: 0.00974 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01150 seconds
Time After: 0.01188 seconds
Time Before: 0.01431 seconds
Time After: 0.01546 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01090 seconds
Time After: 0.01564 seconds
Time Taken: 0.00474 seconds
Memory After: 2,261.719 KB
Time Before: 0.02111 seconds
Time After: 0.02126 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02365 seconds
Time After: 0.02487 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.027081966400146
Time Before: 0.02849 seconds
Time After: 0.02864 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03141 seconds
Time After: 0.03284 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=28395'
Time Before: 0.05075 seconds
Time After: 0.05112 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.049818992614746 seconds with 9 queries, spending 0.0074582099914551 doing MySQL queries and 0.042360782623291 doing PHP things.
