Time Before: 0.01451 seconds
Time After: 0.01869 seconds
Time Taken: 0.00418 seconds
Time Before: 0.01880 seconds
Time After: 0.02008 seconds
Time Before: 0.02049 seconds
Time After: 0.02063 seconds
Time Before: 0.02159 seconds
Time After: 0.02405 seconds
Time Taken: 0.00246 seconds
Time Before: 0.02071 seconds
Time After: 0.02838 seconds
Time Taken: 0.00767 seconds
Time Before: 0.03313 seconds
Time After: 0.03350 seconds
Time Before: 0.03584 seconds
Time After: 0.03702 seconds
Time Before: 0.03230 seconds
Time After: 0.03724 seconds
Time Taken: 0.00494 seconds
Time Before: 0.06464 seconds
Time After: 0.06482 seconds
Time Before: 0.07239 seconds
Time After: 0.07373 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.07568097114563
Time Before: 0.08159 seconds
Time After: 0.08174 seconds
Time Before: 0.08413 seconds
Time After: 0.08578 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=28463'
Time Before: 0.10563 seconds
Time After: 0.10600 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.10443806648254 seconds with 9 queries, spending 0.0091326236724854 doing MySQL queries and 0.095305442810059 doing PHP things.
