Time Before: 0.01700 seconds
Time After: 0.02490 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02503 seconds
Time After: 0.02620 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02681 seconds
Time After: 0.02696 seconds
Time Before: 0.02774 seconds
Time After: 0.03012 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02703 seconds
Time After: 0.03442 seconds
Time Taken: 0.00739 seconds
Time Before: 0.04278 seconds
Time After: 0.04316 seconds
Time Before: 0.04557 seconds
Time After: 0.04676 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04207 seconds
Time After: 0.04696 seconds
Time Taken: 0.00488 seconds
Memory After: 2,261.836 KB
Time Before: 0.06868 seconds
Time After: 0.06886 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08899 seconds
Time After: 0.09025 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.093275785446167
Time Before: 0.10694 seconds
Time After: 0.10736 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11049 seconds
Time After: 0.11200 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788893281, location = '/forums/private.php?do=newpm&explain=1&u=28509'
Time Before: 0.13241 seconds
Time After: 0.13275 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.13132882118225 seconds with 9 queries, spending 0.0090076923370361 doing MySQL queries and 0.12232112884521 doing PHP things.
