Time Before: 0.00735 seconds
Time After: 0.01034 seconds
Time Taken: 0.00299 seconds
Time Before: 0.01046 seconds
Time After: 0.01093 seconds
Time Before: 0.01124 seconds
Time After: 0.01139 seconds
Time Before: 0.01230 seconds
Time After: 0.01464 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01147 seconds
Time After: 0.01855 seconds
Time Taken: 0.00708 seconds
Time Before: 0.02212 seconds
Time After: 0.02250 seconds
Time Before: 0.02498 seconds
Time After: 0.02622 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02143 seconds
Time After: 0.02639 seconds
Time Taken: 0.00496 seconds
Memory After: 2,261.836 KB
Time Before: 0.03641 seconds
Time After: 0.03656 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04278 seconds
Time After: 0.04402 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.046184062957764
Time Before: 0.04915 seconds
Time After: 0.04929 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05171 seconds
Time After: 0.05314 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788872618, location = '/forums/private.php?do=newpm&explain=1&u=28580', badlocation = 1
Time Before: 0.06989 seconds
Time After: 0.07026 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.068637132644653 seconds with 9 queries, spending 0.0079061985015869 doing MySQL queries and 0.060730934143066 doing PHP things.
