Time Before: 0.00154 seconds
Time After: 0.00217 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00224 seconds
Time After: 0.00279 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00305 seconds
Time After: 0.00319 seconds
Time Before: 0.00392 seconds
Time After: 0.00676 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00324 seconds
Time After: 0.01021 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01209 seconds
Time After: 0.01247 seconds
Time Before: 0.01487 seconds
Time After: 0.01614 seconds
Time Before: 0.01151 seconds
Time After: 0.01633 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02166 seconds
Time After: 0.02187 seconds
Time Before: 0.02405 seconds
Time After: 0.02532 seconds
End call of global.php: 0.027078866958618
Time Before: 0.02837 seconds
Time After: 0.02854 seconds
Time Before: 0.03054 seconds
Time After: 0.03197 seconds
SET lastactivity = 1789022659, location = '/forums/private.php?do=newpm&explain=1&u=28619'
Time Before: 0.04478 seconds
Time After: 0.04516 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.043866872787476 seconds with 9 queries, spending 0.0086395740509033 doing MySQL queries and 0.035227298736572 doing PHP things.
