Time Before: 0.00133 seconds
Time After: 0.00191 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00198 seconds
Time After: 0.00256 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00282 seconds
Time After: 0.00294 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00367 seconds
Time After: 0.00675 seconds
Time Taken: 0.00307 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00299 seconds
Time After: 0.01013 seconds
Time Taken: 0.00714 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01199 seconds
Time After: 0.01244 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01590 seconds
Time After: 0.01710 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01134 seconds
Time After: 0.01729 seconds
Time Taken: 0.00595 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02233 seconds
Time After: 0.02253 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02450 seconds
Time After: 0.02577 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.027472019195557
Time Before: 0.02907 seconds
Time After: 0.02929 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03142 seconds
Time After: 0.03284 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1785368554, location = '/forums/private.php?do=newpm&explain=1&u=28627'
Time Before: 0.04540 seconds
Time After: 0.04580 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.044542074203491 seconds with 9 queries, spending 0.0089330673217773 doing MySQL queries and 0.035609006881714 doing PHP things.
