Time Before: 0.01298 seconds
Time After: 0.01968 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01980 seconds
Time After: 0.02025 seconds
Time Before: 0.02053 seconds
Time After: 0.02068 seconds
Time Before: 0.02136 seconds
Time After: 0.02353 seconds
Time Taken: 0.00217 seconds
Time Before: 0.02073 seconds
Time After: 0.02774 seconds
Time Taken: 0.00701 seconds
Time Before: 0.03414 seconds
Time After: 0.03453 seconds
Time Before: 0.03705 seconds
Time After: 0.03861 seconds
Time Taken: 0.00156 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03338 seconds
Time After: 0.03882 seconds
Time Taken: 0.00544 seconds
Memory After: 2,261.836 KB
Time Before: 0.06097 seconds
Time After: 0.06113 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07490 seconds
Time After: 0.07615 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.08478 seconds
Time After: 0.08492 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08724 seconds
Time After: 0.08876 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789108998, location = '/forums/private.php?do=newpm&explain=1&u=28638' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10616 seconds
Time After: 0.10646 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
